External rectangle probing parameters
images/download/attachments/95446766/image2022-4-5_19-34-48.png images/download/attachments/95446766/image2022-4-5_19-44-58.png
External rectangle probing consist of the following steps:
  1. The tool moves the distance specified in the < Feed distance > and approaches the starting position of the cycle. Moving at "Approach feed";
  2. The tool approaches a point remote from the first touch point along its <Target vector> at the <Side clearance 1> distance but elevated at the < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
  3. The tool is lowered by a distance equal to <Top clearance> value + <Depth> value . Moving at "Long link feed" ;
  4. T he tool approaches the first touch point (m oving at "Work feed" ) and then returns (m oving at "Long link feed" ) to previous position;
  5. The tool is lifted up by a distance equal to < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
  6. The tool returns to the starting position;
  7. Steps 2-6 are repeated 3 more times for each touch points;
  8. The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: External rectangle probing value = 8
CmdPrm.Int[-2]
Integer
CmdPrm.Flt[-50]
Double
Feed distance, distance to start position of cycle
CmdPrm.Flt[-51]
Double
Depth, distance from top side to center of touch points
CmdPrm.Flt[-53]
Double
Width 1, distance from Touch point 1 to Touch point 2
CmdPrm.Flt[-54]
Double
Width 2, distance from Touch point 3 to Touch point 4
CmdPrm.Flt[-55]
Double
Top clearance, distance from top side
CmdPrm.Flt[-56]
Double
Side clearance 1, approach distance to touch poin t 1/ touch poin t 2
CmdPrm.Flt[-57]
Double
Side clearance 2, approach distance to touch poin t 3/ touch poin t 4
CmdPrm.Flt[-100]
Double
First touch point value along X-axis
CmdPrm. Flt [-101]
Double
First t ouch point value along Y-axis
CmdPrm. Flt [-102]
Double
First t ouch point value along Z-axis
CmdPrm.Flt[-103]
Double
First target vector value along X-axis
CmdPrm. Flt [-104]
Double
First target vector value along Y-axis
CmdPrm. Flt [-105]
Double
First target vector value along Z-axis
CmdPrm.Flt[-106]
Double
Second touch point value along X-axis
CmdPrm. Flt [-107]
Double
Second t ouch point value along Y-axis
CmdPrm. Flt [-108]
Double
Second t ouch point value along Z-axis
CmdPrm.Flt[-109]
Double
Second target vector value along X-axis
CmdPrm. Flt [-110]
Double
Second target vector value along Y-axis
CmdPrm. Flt [-111]
Double
Second target vector value along Z-axis
CmdPrm.Flt[-112]
Double
Third touch point value along X-axis
CmdPrm. Flt [-113]
Double
Third t ouch point value along Y-axis
CmdPrm. Flt [-114]
Double
Third t ouch point value along Z-axis
CmdPrm.Flt[-115]
Double
Third target vector value along X-axis
CmdPrm. Flt [-116]
Double
Third target vector value along Y-axis
CmdPrm. Flt [-117]
Double
Third target vector value along Z-axis
CmdPrm.Flt[-118]
Double
Fourth touch point value along X-axis
CmdPrm. Flt [-119]
Double
Fourth t ouch point value along Y-axis
CmdPrm. Flt [-120]
Double
Fourth t ouch point value along Z-axis
CmdPrm.Flt[-121]
Double
Fourth target vector value along X-axis
CmdPrm. Flt [-122]
Double
Fourth target vector value along Y-axis
CmdPrm. Flt [-123]
Double
Fourth target vector value along Z-axis
