G85 drilling cycle <CYCLE BORE5(209)>
G85 boring cycle performs rapid approach to the safe level, work feedrate boring will spindle stop at <Z min> level and work feedrate retract to the safe plane level.
images/download/attachments/95446577/Img5_4_31_6.gif
Cycle includes:
  • Rapid approach to <Z safe> level.
  • Work feedrate travel to <Z min> level.
  • Spindle stop.
  • Work feedrate retract to <Safe plane> level.
  • Restore spindle rotation direction and speed.
Command:
CYCLE BORE5(209), A a, MMPM(315), N nm, F f, P p, T t
or
CYCLE BORE5(209), A a, MMPR(316), M nm, F f, P p, T t
Parameters:
Parameter
CLD array
Description
BORE5(209)
CLD[1]
CLD.Type
Cycle type 209 (BORE5).
a
CLD[2]
CLD.A
Hole depth in current measure units (mm or inches).
MMPM(315)
MMPR(316)
CLD[3]
CLD.MMPM
Feedrate measure units:
315 (MMPM) – mm per minute (inches per minute),
316 (MMPR) – mm per revolution (inches per revolution).
nm
CLD[4]
CLD.NM
Work feedrate value.
f
CLD[5]
CLD.F
Safe level.
CLD[6],
CLD[7]
Reserved.
p
CLD[8]
CLD.P
Safe plane level.
CLD[9],
CLD[10]
Reserved.
t
CLD[11]
CLD.Top
Hole top level.
Hole machining cycles <CYCLE>
