G84 drilling cycle <CYCLE TAP(168)>
G84 tapping canned cycle performs rapid approach to safe level, taps the thread on the feedrate retract with reverse spindle rotation.
images/download/attachments/95446574/Img5_4_31_5.gif
G84 Cycle consist of:
  • Rapid approach to <Z safe> level.
  • Work feed rate travel to <Z min> level.
  • Spindle rotation stop.
  • <Reverse spindle rotation> and work feed rate return to <Z safe> level.
  • Restore normal spindle rotation and rapid retract to <Safe plane> level.
Command:
CYCLE TAP(168), A a, MMPM(315), N nm, F f,
P p, T t, S s, PS ps, SC sc, FR fr
or
CYCLE TAP(168), A a, MMPR(316), M nm, F f,
Parameters:
Parameter
CLD array
Description
TAP(168)
CLD[1]
CLD.Type
Cycle type 168 (TAP).
a
CLD[2]
CLD.A
Hole depth in current measure units (mm or inches).
MMPM(315)
MMPR(316)
CLD[3]
CLD.MMPM
Feedrate measure units:
315 (MMPM) – mm per minute (inches per minute),
316 (MMPR) – mm per revolution (inches per revolution).
nm
CLD[4]
CLD.NM
Feedrate value
f
CLD[5]
CLD.F
Z safe level
L
CLD[6]
CLD.L
Cut in value Zl
i
CLD[7]
CLD.I
Withdrawal value Zi
p
CLD[8]
CLD.P
Safe plane level
DWELL(279)
CLD[9]
CLD.DWell
Dwell time keyword.
h
CLD[10]
CLD.H
Dwell time in seconds.
t
CLD[11]
CLD.Top
Hole top level
s
CLD[12]
CLD.Step
Threading pitch
ps
CLD[13]
CLD.Pos
Spindle start angle
sc
CLD[14]
CLD.Socket
Socket type:
0 – floating,
1 – fixed
fr
CLD[15]
CLD.FR
Return feedrate
Hole machining cycles <CYCLE>
