Machine axes brakes control <AXESBRAKE>
Use <AXESBRAKE> command to turn on and off axes brakes if there are axes brakes on the machine. Most commonly this command is used to turn on/off spindle brake (Axis C) on the lathe-milling machines when switching from lathe to milling and vice versa. When performing lathe machining the spindle rotates at high speed, and when milling the spindle is fixed by the brake at specific angle. Using brakes helps to increase the spindle load and reduces the spindle precision positioning mechanisms wear. Also brakes are used on milling machines rotating axes to perform indexed machining.
Command:
AXESBRAKE COUNT N, Axis1Pos(n1) State1, Axis2Pos(n2) State2, ...,
AxisNPos(nN) StateN
Parameters:
Parameter
CLD array
Description
N
CLD[1]
Number of axes affected by this command.
n1
CLD[2]
Index of axis named Axis1Pos in the coordinates list.
State1
CLD[3]
New state of Axis1Pos axis:
ON(71) - brake is on,
OFF(72) - brake is off.
n2
CLD[4]
Index of Axis2Pos axis in the coordinates list.
State2
CLD[5]
New state of Axis2Pos axis:
nN
CLD[2*N]
Index of AxisNPos axis in the coordinates list.
StateN
CLD[2*N+1]
New state of AxisNPos axis:
TCLDAxesBrake: ComplexType
The command to switch the states of axes brake.
Axes: Array, Key="AxisID"
Cmd.Ptr["Axes"] - An array of structures such as AxisBrake . Thus, one command can change the brake state for several axes .
AxisBrake: ComplexType
Cmd.Ptr["Axes"].Item[Index] or Cmd.Ptr["Axes(<AxisName>)"] - Separate element of the Axes array . Contains the state of one machine axis brake . Access to the array elements can either by index or by key field . Here <AxisName> - the key field value, which must match the AxisID field value .
AxisID: String
Cmd.Str["Axes(<AxisName>).AxisID"] - The machine axis identifier, for which is given a new brake state . Determined by the machine schema .
BrakeState: Integer
Cmd.Int["Axes(<AxisName>).BrakeState"] - the new state of the machine axis brake:
0 - Off,
1 - On.
Command syntax allows changing states of multiple axes brakes at once. List of coordinates, which names appear in this command are defined by the SprutCAM machine scheme.
Here are two simple examples of programs handlers for this command.
program AxesBrake
Index: Integer ! Loop counter
AxisNumber: Integer ! Index of an axis in the list of machine axes
BrakeState: Integer ! New state of the axis brake
Index = 1
while Index<=CLD[1] do begin
AxisNumber = CLD[2*Index]
BrakeState = CLD[2*Index+1]
case AxisNumber of
4: begin ! AxisAPos(A) index in the list of machine axes
if BrakeState=71 then Output "M680" ! Turn axis A brake on
else Output "M690" ! Turn axis A brake off
end
6: begin ! AxisAPos(A) index in the list of machine axes
if BrakeState=71 then Output "M68" ! Turn axis C brake on
else Output "M69" ! Turn axis C brake off
end
end
Index = Index + 1
end
end
Another example with Cmd operator using.
program AxesBrake
if Cmd.Ptr["Axes(AxisAPos)"]<>0 then begin ! Axis A is present in this command
if Cmd.Int["Axes(AxisAPos).BrakeState"]=1 then Output "M680" ! Turn axis A brake on
end
if Cmd.Ptr["Axes(AxisCPos)"]<>0 then begin ! Axis C is present in this command
if Cmd.Int["Axes(AxisCPos).BrakeState"]=1 then Output "M68" ! Turn axis C brake on
end
end
<GMA> array
