Triple wall internal corner probing parameters
Triple wall internal corner probing consist of the following steps:
The tool moves the distance specified in the < Feed distance > and approaches the starting point of the measurement cycle that is the intersection of three touch points at a distance specified in <Clearance 1>, <Clearance 2> , <Clearance 3> , respectively, along their vectors . Moving at "Approach feed";
T he tool approaches touch point of the first side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
T he tool approaches touch point of the second side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
T he tool approaches touch point of the third side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
Type |
Description |
CmdPrm.Int[-1] |
Integer |
Probing cycle type: Triple wall internal corner probing value = 15 |
CmdPrm.Int[-2] |
Integer |
CmdPrm.Flt[-50] |
Double |
CmdPrm.Flt[-56] |
Double |
Clearance 1, approach distance to touch poin t on first side |
CmdPrm.Flt[-57] |
Double |
Clearance 2,
t on second side
CmdPrm.Flt[-58] |
Double |
Clearance 3, approach distance to touch poin t on third side |
CmdPrm.Flt[-100] |
Double |
Touch point on first wall value along X-axis |
CmdPrm. Flt [-101] |
Double |
T ouch point on first wall value along Y-axis |
CmdPrm. Flt [-102] |
Double |
T ouch point on first wall value along Z-axis |
CmdPrm.Flt[-103] |
Double |
T arget vector of touch point on first wall value along X-axis |
CmdPrm. Flt [-104] |
Double |
T arget vector of touch point on first wall value along Y-axis |
CmdPrm. Flt [-105] |
Double |
T arget vector of touch point on first wall value along Z-axis |
CmdPrm.Flt[-106] |
Double |
T ouch point on second wall value along X-axis |
CmdPrm. Flt [-107] |
Double |
T ouch point on second wall value along Y-axis |
CmdPrm. Flt [-108] |
Double |
T ouch point on second wall value along Z-axis |
CmdPrm.Flt[-109] |
Double |
T arget vector of touch point on second wall value along X-axis |
CmdPrm. Flt [-110] |
Double |
T arget vector of touch point on second wall value along Y-axis |
CmdPrm. Flt [-111] |
Double |
T arget vector of touch point on second wall value along Z-axis |
CmdPrm.Flt[-112] |
Double |
T ouch point on third wall value along X-axis |
CmdPrm. Flt [-113] |
Double |
T ouch point on third wall value along Y-axis |
CmdPrm. Flt [-114] |
Double |
T ouch point on third wall value along Z-axis |
CmdPrm.Flt[-115] |
Double |
T arget vector of touch point on third wall value along X-axis |
CmdPrm. Flt [-116] |
Double |
T arget vector of touch point on third wall value along Y-axis |
CmdPrm. Flt [-117] |
Double |
T arget vector of touch point on third wall value along Z-axis |
