Change current NC-file operator
<ChangeNCFile> changes the current output NC-file. Thus following NC-code output operators which do not specify NC-file will write NC-blocks into the current NC-file.
Syntax:
ChangeNCFile NewNCFileName$
Description:
<NewNCFileName$> – expression that evaluates into string result.
Sample:
! Changing current NC-file sample
ChangeNCFile "File1.nc" ! changing the current NC-file
Output "кадр УП" ! this line will be output into the "File1.nc" file
The block output statement <OUTBLOCK>
Statement of direct output into the block <OUTPUT>
