External task call operator
Use <ShellExec> operator to execute a shell command or to call an external task.
Syntax:
ShellExec CommandLine$
Description:
<CommandLine$> – string expression.
Then executing this operator Postprocessor will run the operating system shell command interpreter (CMD.EXE) and pass it the <CommandLine$> as command (this operator is effectively executing "cmd /c CommandLine$"). Note that the console window is not displayed.
Sample:
! OS command execution
ShellExec "erase temp\*.*" ! Clear the temp folder
