Statement of direct output into the block <OUTPUT>
This operator outputs the content of a string variable by separate block of NC-program.
Format:
OUTPUT {<FileName$>}, S$
Description:
<S$> – the identifier of a string variable. The literal constant or string expression may be the parameter of this operator.
Use optional <FileName$> parameter to specify the file where the system outputs the NC-block. If the parameter is omitted then the NC-block is output into the current file. If "*" is specified as a file name then the NC-block would be output into the main file, also the current file will be changed. If <FileName$> specifies the name of a file then corresponding tab will be created and the current file would be changed accordingly.
Samples:
! The output of the first symbol into NC-code
OutPut “%”
Name$ = “ John ”
F$ = “Lord”
! The output of string into NC-program
OutPut “Programmer ”+Name$+” “+F$
! The string ‹Programmer John Lord› will be written into NC-program
! Sample of usage the FormBlock and Output usage instead OutBlock
FormBlock
Output OutStr$
! Two these statements work as OutBlock
The block output statement <OUTBLOCK>
The block forming statement <FORMBLOCK>
