Machine's approach/return list
Approach/return list overview
In the "Leads" section of machine's xml file several rules for approach/return can be specified for convenient use. Each item of the list has a name to distinguish it from other rules. If the rule in the list was edited, it will affect all the operations which reference this rule. To assign a rule to operation, select the corresponding item in the operation's approach/return combobox:
Editing approach/return list
There are 2 ways of editing the machine's approach/return list.
Direct editing of machine's xml file (shown in this article)
Using a approach/return edit form. To display the form click "Custom.." in the approach/return combobox.
Editing machine's xml file
The machine's approach/return list is located in the <Leads> section (previously here could be specified just one approach/return rule). <ApproachCommands> and <ReturnCommands> are the names of the respective subsections. Each rule has 3 fields:
<RuleID> - unique GUID of the rule. It's used as a method for operations to reference a particular rule. See the operation's GUID as an example.
<Name> - name of the rule.
<Command> - the rule itself, the sequence of intermediate points of approach/return. To specify the approach/return with collision avoidance use keyword 'Auto'.
<Type> - type of the rule which defines possible use case for the approach/return. Currently there are 4 available types:
LCS - approach/return can be used only if the local coordinate system is enabled for the operation.
TCPM - can be used only if the tool center point management (TCPM) is enabled (both LCS and TCPM cant be enabled at the same time).
General - the rule can be used only if both LCS and TCPM are off.
Undefined - the rule doesnt depend on LCS or TCPM state. If the type wasn't explicitly defined it is assumed to be 'Undefined'.
Below is the partial example of xml file:
<SCType ID="MaxTurn65WithCounterSpindle" Caption="MaxTurn65 with Counter Spindle" type="MaxTurn65" Enabled="true"> <GUID DefaultValue="{8E0CEF0A-8045-436D-89FD-BBE70D387AB1}"/> <Priority DefaultValue="172"/> <Name DefaultValue="MaxTurn 65 with Counter Spindle"/> <Comment DefaultValue="MaxTurn 65 with Counter Spindle"/> <Leads> <ApproachCommands> <SCArray> <Rule> <RuleID>{41D3BB1C-2F23-47AC-B5F9-5DAF7030A015}</RuleID> <Command>C;Z10;X;Z</Command> <Name>Left spindle approach</Name> </Rule> <Rule> <RuleID>{54FC19E5-8ACB-491A-8E94-FC9990FC8680}</RuleID> <Command>C2;Z-10;X;Z</Command> <Name>Right spindle approach</Name> </Rule> </SCArray> </ApproachCommands> <ReturnCommands> <SCArray> <Rule> <RuleID>{380D355A-6708-4C86-BA69-7521A0198A8E}</RuleID> <Command>Z10;X;Z;C</Command> <Name>Left spindle return</Name> </Rule> <Rule> <RuleID>{18B61D64-EEC9-4403-8922-CCFCC017E53E}</RuleID> <Command>Z-10;X;Z;C2</Command> <Name>Right spindle return</Name> </Rule> </SCArray> </ReturnCommands></Leads>Approach/return rule types
Often (for example, in 5 axis machines) different approach/return rules are needed depending on the operation's LCS and TCPM options state. Selecting the wrong rule can be quite costly, that's why rule types were introduced. In the approach/return combobox are visible only the rules with the right type (or undefined type). When creating new operation, it will have the first rule applicable for her default TCPM and LCS state (if there are no such rules, the rule will be 'From previous operation'). If the LCS or TCPM settings are changed on the "Setup" tab and the current rule is not compatible with the new setting, it will be changed for the first compatible one.
Conversion of the older version machines/projects
When the older version machine is opened for the first time, the list consisting the machine's previous approach/return rule is created. Also the root operation references this rule (if no custom rule is assigned to it). As a result, operations having 'From root operation' rule type use the same approach/return as before.
Approach and return rules overview
