SOLIDWORKS™ toolbar & import addin
The toolbar allows you to export geometric data from SOLIDWORKS™ to SprutCAM™.
The addin allows you to import project files SOLIDWORKS™.
Supported file extensions: SLDASM, ASM, SLDPRT, PRT, SLDDRW, DRW, X_B, X_T, STP, STEP.
The required application (SOLIDWORKS™) must be installed on your computer for the correct work of this option.
