SolidEdge™ toolbar & import addin
The toolbar allows you to export geometric data from SolidEdge™ to SprutCAM™.
The addin allows you to import SolidEdge™ project files.
Supported file extensions: ASM, DFT, PAR, PSM, MDS, PWD, DGN, DXF, DWG, PRT, SAT, STP, STEP, X_B, X_T.
The required application (SolidEdge™) must be installed on your computer for this option to work.
