Interactive rotate
images/download/attachments/95432425/image2019-1-10_17-28-55.png
Press and hold the right mouse button, and drag to the main visualization screen to rotate. Or use the Rotate view popup menu item of the graphic window to switch on the rotate view mode. Drag up and down to rotate around the horizontal screen axis. Drag left and right to rotate around the vertical screen axis.
Press and hold [X], [Y] or [Z] button and drag the mouse to rotate around X, Y or Z axis of the active coordinate system. Hold [Space] while rotating to loop the rotation and animate it.
Changing the view vector is also available via the <Standard views> button.
Click the middle mouse button (wheel) in the graphics window provides complete rotation of the current view vector to the nearest standard.
The program also supports various 3D mouse devices, e.g., SpaceNavigator.
Graphic window and visualization control
