Operations matrix
Configurations
Operations
Express
Wire EDM
Lathe
Cutting
2.5x Mill
3x Mill Entry
3x Mill Advanced
Rotary
5x Mill
Operations for 2/2.5D milling
2D contouring
Engraving
2.5D pocketing
2.5D wall machining
2.5D cover machining
2.5D chamfer machining
Pocketing
Hole machining
Operations for 3D milling + indexed rotary axes
3D contouring
Flat land machining
Waterline roughing operation
Plane roughing operation
Waterline finishing operation
Plane finishing operation
Optimized plane operation
Complex operation (waterline-plane)
Morph operation
3D Helical operation
Scallop operation
Face milling
FBM
4D contouring operation
4D surfacing
Rotary waterline
Rotary roughing
Rotary finishing
Morph 4D
5D contouring
5D surfacing
5D by meshes
Rest machining
Corners cleanup
Pencil
Chamfering
Lathe
OD roughing, ID roughing operations
OD finishing, ID finishing operations
Lathe facing operation
Lathe hole machining operation
Lathe part-off operation
OD grooving, ID grooving, Face grooving operations
OD threading, ID threading, Profile threading operations
Cut machining
Jet cutting
Jet cutting 4D
Jet cutting 5D
Wire EDM
2D contouring
4D contouring
Cladding
Area cladding
Curve cladding
Cladding 3D
Cladding 5D
Knife cutting
Knife cutting 2D
Knife cutting 6D
Disc tool
Disc roughing
Disc cutting 2D
Disc cutting 6D
Auxiliary operations
Group
Auxiliary
G-code based, G-code based lathe
✓ — available
○ — option (need additional license)
