5D MW - advanced 5 axis milling module
This module is useful for creating tool paths for 3, 4, and 5 axis machines, and industrial robots (the last only for configuration 'Robots + 5D MW').
There are operations:
images/download/attachments/95438720/f_clip1155.png
This module is available for the next configuration .
5 axis multi surface
5 axis swarf
Impeller blade surface swarf finishing
Impeller floor surface with tilt curve
Impeller floor surface without tilt curve
Impeller roughing
Cavity with tilt curve
Turbine blade rotary machining
Electrode machining
Projection
