Approach, retraction, and plunge methods
Use the <Links/Leads> dialog to specify parameters that define tool approach to cutting passes and tool retraction from cutting end point. The actual dialog window is changed according to the current operation.
images/download/attachments/95436203/image2022-4-20_15-18-16.png
Mill machining
Approach and retraction of mill operations
Plunge methods of mill operations
Compound approaches and retractions of mill operations
Controlling tool's transition between operations
