4-axis milling with engraving and pocketing operations
Engraving and pocketing operations allow to define the job assignment as the set of the closed contours. Everyone of it defines the <Pocket> or the <Boss> of the model.
images/download/attachments/95435463/image2022-4-3_16-48-55.png
Besides, it is possible to set the <Base surface> in the current operations, on which one of the defined contours will be projected. The base surface is a plane, cylinder or the solid of revolution.
images/download/attachments/95435463/image2022-4-3_16-50-16.png
The contours of the job assignment can define the boss and pockets directly on the base surface or to be an unrolled curves of it. In contrast to the <Cylindrical interpolation> the machine can not have the rotary axis that rotates the workpiece.
5 axis machining
Engraving operation
Using design features in an Engraving/Pocketing operation
Job assignment for engraving and pocketing operations
