Plunge roughing
Plunge roughing option generates vertical passes from Roughing Waterline, Plane and Pocketing operations result.
This option requires a tool that is designed to handle axial cutting.
Parameters
Core radius
Radius of the central non-cutting part of the tool.
Step
Step between passes.
Pull back distance
Distance for which tool pulls back away from the model.
Additional pass
Creates an additional pass if can't process the workpiece on the current pass.
This function is useful when plunge option cannot process corner areas.
Step will be ignored for additional passes.
Feed distance
Distance (along the tool axis) where vertical motion switch to work feed.
