Corners cleanup
images/download/attachments/95435383/crm1.png
The rest machining operation takes the diameter of the previous tool as a parameter and generates passes where the previous tool would leave unmachined material.
Parameters
Previous tool diameter
images/download/attachments/95435383/crm2.png
The diameter of a spherical mill which is used for the rest material calculation.
Cut depth
images/download/attachments/95435383/crm3.png
The maximum cut depth for a cut
Step
The maximum step-over between passes
Strategies
Along
images/download/attachments/95435383/crm4.png
The passes are generated along the corners.
Across
images/download/attachments/95435383/crm7.png
The passes are generated across corners
Combined
For shallow areas - along passes are generated, for steep areas - across passes are generated.
Job zone
Machining surfaces
The passes are generated only on places where the tool contacts the machining surfaces. If the machining surfaces are missing, the toolpath is generated against the whole part.
Bottom level
A bottom level can be set for the passes
See example of operation on YouTube:
