Point welding operation
images/download/attachments/92880504/image2022-5-16_18-24-47.png
Operation can be used to images/download/thumbnails/92880504/image2022-5-20_10-7-45.png Tack weld and images/download/thumbnails/92880504/image2022-5-20_10-8-5.png Spot weld.
Job assignment
In the strategy tab, you need to select the type of welding:
images/download/attachments/92880504/image2022-5-16_16-18-11.png
images/download/attachments/92880504/image2022-5-16_16-19-26.png
For both types the job assignment is the same.
The job assignment images/download/thumbnails/92880504/image2022-5-20_10-9-9.png consists of two types of points:
images/download/attachments/92880504/image2022-5-16_17-39-17.png
  1. images/download/attachments/92880504/weld.png Weld Point
  2. images/download/thumbnails/92880504/Move.png Move Point
These points can be used to construct a chain of trajectories:
images/download/attachments/92880504/image2022-5-16_16-56-19.png
Drag points
These points can be moved by dragging.
They attach to faces images/download/thumbnails/92880504/image2022-5-20_10-10-58.png , curvesimages/download/thumbnails/92880504/image2022-5-20_10-11-38.png , splinesimages/download/thumbnails/92880504/image2022-5-20_10-11-38.png , edgesimages/download/thumbnails/92880504/image2022-5-20_10-12-21.png , verticesimages/download/thumbnails/92880504/image2022-5-20_10-12-55.png . Tool axis rotates automatically when attached.
Move points can be easily moved using Smart snap images/download/attachments/92880504/image2022-5-16_18-29-40.png :
images/download/attachments/92880504/image2022-5-16_18-28-54.png
Position of the point can also be specified as an offset from the auxiliary yellow point.
To do this, first select the yellow point:
images/download/attachments/92880504/image2022-5-20_10-41-28.png
You can also rotate the axis vector by dragging the visual vector:
images/download/attachments/92880504/image2022-5-16_17-7-31.png
Point parameters
Points contains the following parameters:
images/download/attachments/92880504/image2022-5-20_9-34-53.png
images/download/attachments/92880504/image2022-5-20_9-35-36.png
images/download/thumbnails/92880504/image2022-5-20_9-38-4.png Caption - point name
images/download/thumbnails/92880504/image2022-5-20_9-38-16.png Position - point coordinates.
images/download/thumbnails/92880504/image2022-5-20_9-38-32.png Angles - tool axis inclination angle at point
images/download/thumbnails/92880504/image2022-5-20_9-39-29.png Fix vZ - if enabled point vector does not change when dragged
images/download/thumbnails/92880504/image2022-5-20_9-39-39.png Fix vX - enable 6 axis edit mode:
images/download/attachments/92880504/image2022-5-16_17-21-45.png
images/download/attachments/92880504/MultiGOTO.png Motion type - is set by what type to move to the point:
  • images/download/attachments/92880504/MultiGOTO.png MultiGoto - Multi coordinate movement
  • images/download/attachments/92880504/PGoto.png PhysicGoto - Physical machine axes movement
  • images/download/attachments/92880504/AvoidColls.png Avoid collisions - Collision avoidance movement
images/download/thumbnails/92880504/image2022-5-20_9-56-39.png Axes - machine axis at the current point.
When changing axes, two buttons appear:
images/download/attachments/92880504/image2022-5-20_9-58-15.png
images/download/attachments/92880504/ok.png - moves the point to the tip of the machine
images/download/thumbnails/92880504/cancel.png - returns previous values
images/download/attachments/92880504/minus.png images/download/thumbnails/92880504/Plus.png - 360/+360
images/download/thumbnails/92880504/image2022-5-16_17-36-18.png Flip - controls flips in the robot
Auxiliary Point
images/download/thumbnails/92880504/image2022-5-20_10-14-13.png Weld point also contains additional auxiliary points:
  1. Clearence
  2. Engage
  3. Retract
images/download/attachments/92880504/image2022-5-20_10-1-50.png
images/download/attachments/92880504/image2022-5-16_18-4-55.png
