Editing links in a block
In the inspector, in the <Constraints> tab, a list of the active element's links is shown.
In block mode, you can disable / enable the restriction by clicking on the link image.
To create links <Parallelism>, <Tangency>, <Perpendicularity>, <Coaxiality>, <Equality> in block mode, press the corresponding button and sequentially select a pair of objects.
Releasing the button will return the link enable/disable mode. After exiting the block mode, disconnected links are permanently disabled.
