Register List
INCT_SysState - machine-stand system status interface. At the moment, the interface provides work with the generated list of registers (taking into account the settings file, the program library and the interpreter's parents). To distinguish the generated list of registers from the initial registers of the interpreter, the settings file and the parent interpreters, the generated list of registers is called the base list of registers.
Method
Method Description
Description of use
FindFirstRegister
The function returns the first, found by address, base register (interface INCT_BaseReg).
Input parameter: Addr (string) - register address
The function can be used to search for the base register by address when analyzing the text of the G-code for implementing INCT_Interpreter.TransLine.
FindNextRegister
The function returns the next one, starting from FromIdx, found at the address of the base register (interface INCT_BaseReg).
Input parameter: FromIdx (integer) - the starting index, Addr (string) - the address of the register
Get_BR_ByIndex
The function returns the base register by index (INCT_BaseReg interface)
Input parameter: Index (integer) - register index.
The function can be used to obtain the base register by index when searching the base registers (for example, to obtain the initial values of the tool position axes associated with the base registers).
Get_BR_ByName
The function returns the base case by name (interface INCT_BaseReg)
Input parameter: Name (integer) - the name of the register.
The function can be used to search for the base register by name, to determine the index of the register when implementing INCT_Interpreter.DefineRegister.
Get_BR_Count
The function returns the number of base registers.
The function can be used to obtain the number of base registers for subsequent enumeration of base registers (for example, to obtain initial values of tool position axes associated with base registers).
INCT_BaseReg - the interface provides work with the base register.
Method
Method Description
Description of use
SetValue
The method sets a new value to the base register. The base register has three fields for storing a value — a string, a fractional number, an integer. If the new value is not empty, then it is written in a field with a string, converted and written into fields with integer and fractional numbers.
Input parameter: Value (string) - new register value.
The function can be used in the interpretation of tokens and semantic structures that affect the value of the register (for example, functions).
Get_Addr
The function returns the address of the base register (string).
No input parameters.
Functions can be used to obtain the corresponding parameters of the base register during the initialization, translation or interpretation of the text of the G-code.
Get_Name
The function returns the name of the base register (string).
Get_Id
The function returns the identifier of the base register in the kinematic scheme of the machine (string).
Get_Idx
The function returns the index of the base register in the register list (integer).
Get_Str
The function returns the string value of the base register (string).
Get_Int
The function returns the numeric value of the base register (integer).
Get_Flt
