Wire EDM feature
Wire EDM feature is a chain of ruled surfaces with top and bottom edges lying in horizontal planes. SprutCAM X automatically recognizes top and bottom curves of the element, also it places synchronization lines in appropriate parts of contours.
images/download/attachments/84218056/FBM_WireEDMFeature_1.png images/download/attachments/84218056/FBM_WireEDMFeature_2.png
For a convenient and rapid creation of new Wire EDM operation to machine a 3D model select any of faces belonging t constructive elements you want to machine and create a new operation by selecting it in the drop-down list of the <New> button. SprutCAM X auto detects constructive elements you marked, adds them to the job assignment and setups properties of the operation according to parameters of constructive elements.
To add a constructive element to existing operation select a surface belonging to the constructive element in the graphic window and press one of buttons <Add cap> or <Add hole>. SprutCAM X will setup operation parameters according to the constructive element properties if the job assignment was empty.
Wire EDM machining
Job assignment of wire EDM machining operations
2D job assignment item properties
4D job assignment item properties
Synchronization lines
Bridges
Multiselect feature
