Multiselect feature
Use the floating actionbar to select items that have common attributes. Select any item and activate the activate the multiselect option.
images/download/thumbnails/84218053/embim50.png
Pop-up panel will show properties of the selected item. Use checkboxes to filter selection based on the values of properties of selected element. If a property is checked only items with equal value of that property are selected. For example to check all items that have stock of 0mm select one such item and check the <Profile stock> property.
Wire EDM machining
Job assignment of wire EDM machining operations
2D job assignment item properties
4D job assignment item properties
Synchronization lines
Bridges
Wire EDM feature
