Holes sorting
The holes sorting window allows you select one of the type of sorting using some parameters to sort holes list.
The system has four pattern of holes sorting: <Rectangular>, <Circular (Rings)>, <Circular (Sectors)>, <Optimal>.
images/download/attachments/84217240/image2022-4-5_17-41-22.png
The pattern <Rectangular> allows you to sort the holes along XY rows. This type of sorting has the following parameters:
  • images/download/thumbnails/84217240/image2020-10-22_9-30-52.png — starting position of calculation rows
  • images/download/thumbnails/84217240/image2020-10-22_9-30-18.png — angle to rotate rows
  • images/download/thumbnails/84217240/image2020-10-22_9-34-28.png — distance between rows
  • images/download/thumbnails/84217240/image2020-10-22_9-39-43.png — direction to calculate drilling trajectories (Available values: < Top-down >, < Bottom-up >)
  • images/download/thumbnails/84217240/image2020-10-22_9-59-20.png — order of moving between rows (Available values: <One way>, <ZigZag>, <Optimal>)
  • images/download/thumbnails/84217240/image2020-10-22_10-2-42.png — change order in the opposite direction
If <Start point> is unchecked then the system will select first hole of drilling trajectories.
The pattern <Circular (Rings)> allows you to sort the holes along the rings located from specified center. T his type of sorting has the following parameters:
  • images/download/thumbnails/84217240/image2020-10-22_10-20-24.png — center of calculation rings
  • images/download/thumbnails/84217240/image2020-10-22_10-28-42.png — angle to set start position
  • images/download/thumbnails/84217240/image2020-10-22_10-31-19.png — distance between center and first ring
  • images/download/thumbnails/84217240/image2020-10-22_10-33-32.png — distance between rings
  • images/download/thumbnails/84217240/image2020-10-22_10-34-48.png — direction to calculate drilling trajectories (Available values: < Clockwise >, < Counter-clockwise >)
  • images/download/thumbnails/84217240/image2020-10-22_10-36-2.png — direction to calculate drilling trajectories (Available values: < Outside to inside >, < Inside to outside >)
  • images/download/thumbnails/84217240/image2020-10-22_9-59-20.png — order of moving between rings (Available values: <One way>, <ZigZag>, <Optimal>)
The pattern <Circular (Sectors)> allows you to sort the holes using sectors of a circle. T his type of sorting has the following parameters:
  • images/download/thumbnails/84217240/image2020-10-22_10-20-24.png — center of calculation sectors
  • images/download/thumbnails/84217240/image2020-10-22_10-39-51.png — distance between sectors (There are two input mode: <Count> and < Degrees >)
  • images/download/thumbnails/84217240/image2020-10-22_9-59-20.png — order of moving between sectors (Available values: <One way>, <ZigZag>, <Optimal>)
The pattern <Optimal> is similar to < Optimal > in < Strategy > except for configurable settings.
images/download/attachments/84217240/image2022-4-5_17-42-40.png
  • images/download/thumbnails/84217240/image2020-10-22_9-30-52.png — starting hole to calculation optimal drilling trajectories
  • images/download/thumbnails/84217240/image2020-10-22_10-2-42.png — change drilling trajectories in the opposite direction
If < Start point > is unchecked then the system will select first hole of drilling trajectories.
