Top and bottom levels
The common task while machining prismatic and turn-milling parts is to define the <Top> and <Bottom level> parameters of an operation based on the geometrical position of the machined feature. The most straightforward way to accomplish this task is to use the corresponding items of the <Job Assignment>.
As source geometry for the <Top> and <Bottom Level> items of the <Job Assignment> can be used any 3d Model entities including groups. The actual values of the levels are computed from the bounding box of the geometry entity. In addition you can set a positive or negative stock in the item property dialog.
At the following picture you can see a turn-milling part. We will machine the front open slot.
images/download/attachments/84217037/f_clip0061.png
Using open job zones we construct the machining zone in the XY plane. As you can see at the picture below we have to limit toolpath by Z. Both top and bottom levels have to be adjusted.
images/download/attachments/84217037/f_clip0062.png
To accomplish this task we will add the side face of the slot as the <Bottom Level> item into the <Job Assignment>.
images/download/attachments/84217037/image2022-4-4_17-49-22.png
The generated toolpath will look like depicted below.
images/download/attachments/84217037/f_clip0064.png
To limit toolpath from top we add the outer diameter of the slot as the <Top Level> item into the <Job Assignment>.
images/download/attachments/84217037/image2022-4-4_17-49-55.png
The resulting toolpath is pretty good:
images/download/attachments/84217037/f_clip0066.png
Mill machining
