Drilling cycle (G87, W5DBore7(487))
Boring cycle performs tool approach to the hole center, hole boring with stop at minimum level and manual retract to the <Return> level.
images/download/attachments/84216553/G87.PNG
Boring canned cycle <G87> consists of:
  • Rapid travel to the hole center at the <Z return> level.
  • Rapid travel to the <Z safe> level.
  • Work feedrate travel to the <Z min> level.
  • <Spindle stop>. If <Oriented retract> check box enabled, then spindle stops with the fixed angle of orientation and then the tool shifts slightly sideways in accordance with a given displacements.
  • Manual retract to the <Z return> level.
  • Restore spindle rotation direction and speed.
Options on the <Oriented retract> panel allow retraction without contact the tool with machined surface at the exit. To do this, after the final depth of hole is reached the spindle stops with a strictly defined angle and a slightly shifts to the side. Then tool returns to the top level with a stationary spindle.
images/download/attachments/84216553/image2022-4-7_10-49-20.png
To edit the following parameters are available: the angle of the oriented spindle stop in degrees and the coordinates of tool offset after a stop.
Hole machining operation
