Spindle <SPINDL>
<SPINDL> command passes spindle control parameters. <SPINDLE> command is used to define spindle rotation frequency or range of frequencies, surface speed, etc.
Command:
SPINDL ON(71)|OFF(72)|ORIENT(246), NO n, K k,
MODE RPM(0)|RANGE(1)|CSS(2) {, SPEED c}
Parameters:
Parameter
CLD array
Description
ON(71)OFF(72) ORIENT(246)
CLD[1]
CLD.OnOff
Command type:
ON(71) – spindle rotation on,
OFF(72) – spindle rotation off,
ORIENT(246) – oriented spindle stop.
n
CLD[2]
CLD.NO
Rotation frequency, spindle rotation angle or maximum spindle rotation frequency in CSS mode.
k
CLD[3]
CLD.K
Range of rotation frequencies.
RPM(0)
RANGE(1)
CSS(2)
CLD[4]
CLD.Mode
Mode of the rotation frequency definition:
RPM(0) – revolutions per minute,
RANGE(1) – range of spindle rotation frequencies,
CSS(2) – constant surface speed mode.
c
CLD[5]
CLD.CSS
Constant surface speed value for the CSS mode.
To create ISO postprocessor using masks use ISO.M values which correspond to <SPINDL> parameters.
CLD parameter
ISO value
CLD[1] = 71
ISO.M = 3
CLD[1] = 72
ISO.M = 5
