Cooling <COOLNT>
<COOLNT> command turns on or off the machine cooling systems. The first parameter specifies command type: activation or deactivation. The second parameter is the tube number which is affected by the <COOLNT> command.
Command:
COOLNT ON(71)|OFF(72), N n
Parameters:
Parameter
CLD array
Description
ON(71)
OFF(72)
CLD[1]
CLD.OnOff
Command type:
ON(71) – activate coolant,
OFF(72) – deactivate coolant.
n
CLD[2]
CLD.N
Coolant tube number:
1 – flood,
2 – mist,
3 – tool.
To create ISO postprocessor using masks use ISO.M values which correspond to parameters:
CLD parameter
ISO value
CLD[1] = 71
ISO.M = 8
CLD[1] = 72
ISO.M = 9
