Records
<Record> is a keyword used to describe variables - structures. The syntax for declaring a variable of type <Record> is:
RecVarName: Record
  RecFieldName1: Type1
  RecFieldName2: Type2
  RecFieldNameN: TypeN
End
Where
  • RecVarName – name of varriable;
  • RecFieldName1...RecFieldNamen – variable field names;
  • TypeX – record field type. It can be any simple type, record or static array of the above types.
Example:
Rec1, Rec2: record
X, Y, Z: real
P: array [3,3] of integer;
S1, S2: string
end
RR: array [10] of record
X, Y, Z: real
end
Rec11: record
field1: integer
field2: array 10 of string
field3: record
nestedField1: real
nestedField2: array 5 of integer
end
end
Using Records
Record fields are accessed by using the access operator: "."
In order to assign a value to the record field, you need to use the following expression:
<RecordName>.<FieldName1>{.<NestedFieldName2>...} = x
Example:
Rec1.X = 1; Rec1.Y=2
Rec1.P[1,1] = 0
Rec1.S1 = "W100"
for i=1 to 10 do begin
RR[i].X = i
RR[i].Y = 0
RR[i].Z = 50
end
rec3.field3.nestedField2[1]=33
You can use the value stored in the field as follows:
x = <RecordName>.<FieldName1>{.<NestedFieldName2>...}
Example:
x1=Rec1.X; y1=Rec1.Y
z2=RR[2].Z
