Wire EDM pass properties PPFun WEDMPassItem(57)
Wire EDM pass properties command WEDMPassItem(57) is generated by EDM operations of SprutCAM system. It is used to transfer information to the postprocessor about which contour and pass of toolpath the nested CLData commands belong to. It appears at the start of contour movements and before the end of contour movements for each separate pass.
Parameters:
Parameters |
Description |
Command SubCode |
CLD[1] |
CLD.SubCode |
WEDMPassItem(57) – the type of PPFun command - Wire EDM pass properties. |
On/Off |
CLD[2] |
Contour start-stop flag: On(71) - start of contour, Off(72) - end of contour. |
Contour type |
CLD[3] |
The type of contour - general type pass (0) or coreless pocketing pass (1). |
Item index |
CLD[4] |
Index of this contour in the list of Job assignment items of the operation. |
Pass index |
CLD[5] |
Offset pass index |
Pass type |
CLD[6] |
The type of pass:
