<STRUCTURE> command
The <STRUCTURE> command allows us to represent a tree structure of CLData commands as a linear list of commands.
Command:
STRUCTURE ON(71)|OFF(72), TYPE(Level), Comment(Level: -65)
In SprutCAM toolpath of each operation is represented as a tree, separated into groups and subgroups, within which are placed the usual commands of moving tool, turn on the spindle or feed, etc. Inside the postprocessors generator toolpath is represented as a linear list of commands that is not divided into groups. <STRUCTURE> command intended to preserve the original information as to in what group was originally located CLData command. Each group is converted into two commands: <STRUCTURE ON(71)> and <STRUCTURE OFF(72)>. The first command defines the start of the group, and the second one - the end of the group. All items that are placed inside a group will be located between these two commands. As well as groups can be nested within each other, inside a <STRUCTURE ON(71)> ... <STRUCTURE OFF(72)> block can be nested several other blocks <STRUCTURE ON(71)> ... <STRUCTURE OFF(72)>.
images/download/attachments/95446853/StructureMCDTreeToCLD.png
Parameters:
Parameter
CLD array
Description
ON(71),
OFF(72)
CLD[1]
Sign that this command is the beginning or the end of the group:
ON(71) - command defines the beginning of group,
OFF(72) - command defines the end of group.
TCLDSStructure: ComplexType
Command that defines the structure
IsClose: Integer
Cmd.Int["IsClose"] - Sign that this command is the beginning or the end of the group:
0 - command defines the beginning of group,
1 - command defines the end of group.
NodeType: String
Cmd.Str["NodeType"] - A string that specifies the type of group. For example, Approach - a group of approach movings, Level - a layer of machining, etc. This string is not translated into local languages.
Comment: String
Cmd.Str["Comment"] - The group name that is displayed in the SprutCAM's toolpath tree. Can be translated into local languages ​​and contain arbitrary characters.
