Deep drilling with chip removing <CYCLE DEEP(153)>
Deep drilling with chip removing cycle performs rapid approach to the safe level and repeated drilling according to specified cut-in depth value <ZI> and withdrawal <Zi> values.
images/download/attachments/95446592/Img5_4_31_3.gif
Cycle includes:
  • Rapid travel to the <Z safe> level.
  • Work feedrate travel to the <Zl>.
  • Rapid retract to the <Z safe> level.
  • Rapid travel to the <Zl> - <Zi> level.
  • Work feedrate travel to the <Zl> + <Zi> level.
  • Rapid travel to the 2*<Zl> - <Zi> level.
  • Repeat until the hole depth level is reached.
  • Rapid retract to the <Safe plane> level.
Command:
CYCLE DEEP(153), A a, MMPM(315), N nm, F f, L l, I i, P p, T t
or
CYCLE DEEP(153), A a, MMPR(316), M nm, F f, L l, I i, P p, T t
Parameters:
Parameter
CLD array
Description
DEEP(153)
CLD[1]
CLD.Type
Cycle type 153 (DEEP).
a
CLD[2]
CLD.A
Hole depth in current measure units (mm or inches).
MMPM(315)
MMPR(316)
CLD[3]
CLD.MMPM
Feedrate measure units:
315 (MMPM) – mm per minute (inches per minute),
316 (MMPR) – mm per revolution (inches per revolution).
nm
CLD[4]
CLD.NM
Work feedrate value.
f
CLD[5]
CLD.F
Safe level.
L
CLD[6]
CLD.L
Cut in value Zl
i
CLD[7]
CLD.I
Withdrawal value Zi
p
CLD[8]
CLD.P
Safe plane level.
CLD[9],
CLD[10]
Reserved.
t
CLD[11]
CLD.Top
Hole top level.
Hole machining cycles <CYCLE>
