The main toolbar
images/download/attachments/95446171/main_toolbar.jpg
  • images/download/attachments/95446171/btn-new.jpg – Creates the new postprocessor's tuning file. The system resets its state before creation.
  • images/download/attachments/95446171/btn-load.jpg – Opens the postprocessor's tuning file, which is saved earlier. The system resets its state before loading.
  • images/download/attachments/95446171/btn-save.jpg – Saves the postprocessor's tuning file with the current name.
  • images/download/attachments/95446171/btn-reload.jpg – Requests new CLData files from SprutCAM.
  • images/download/attachments/95446171/btn-scam.jpg – Opens the technological commands file, generated by SprutCAM.
  • images/download/attachments/95446171/btn-compile.jpg – Runs the compilation of the command processing programs.
  • images/download/attachments/95446171/btn-run.jpg – Runs the generation of the NC-program from the files of the tool motion trajectory. If the command processing programs aren't compiled, the compilation will be activated first.
  • images/download/attachments/95446171/btn-stop.jpg – Break NC-program generation.
  • images/download/attachments/95446171/btn-stepin.jpg – Generate NC-program with stopping in subprograms.
  • images/download/attachments/95446171/btn-stepover.jpg – Generate NC-program with without stopping in subprograms.
  • images/download/attachments/95446171/btn-stepup.jpg – Generate NC-program up to current position in a CLData.
  • images/download/thumbnails/95446171/btn-pause.jpg – Pause NC-program generation.
  • images/download/attachments/95446171/btn-breakpoint.jpg – Add breakpoint in a handler of technological commands or CLData files.
  • images/download/attachments/95446171/btn-add-watches.jpg – Adds a new variable to the list of watches.
  • images/download/attachments/95446171/btn-evaluate.jpg – Compute variable or expressions. The evaluation is possible only in a debug mode.
  • images/download/attachments/95446171/btn-cancel.jpg – Cancel the last fluctuation made in the program of a handler technological command or a mask.
  • images/download/attachments/95446171/btn-return.jpg – Return the last fluctuation made in the program of a handler of a technological command or a mask.
  • images/download/thumbnails/95446171/btn-machine.jpg – Opens the window for the data about NC-machine and CNC-system.
  • images/download/thumbnails/95446171/btn-transliterate.jpg – Open transliteration properties dialog.
    Application toolbar placed on the top left panel of the main window. There are drop-down menus associated with 2 buttons.
images/download/attachments/95446171/menu-inp.jpg
  • images/download/attachments/95446171/btn-settings.jpg – Opens system setup window.
  • images/download/thumbnails/95446171/001-26-AppLogo.png – Information about Postprocessors generator.
Help menu consist of actions that allow to get answers to emerging questions.
images/download/attachments/95446171/menu-help-eng.jpg
  • images/download/attachments/95446171/btn-h-contents.jpg – Shows postprocessors generator help.
  • images/download/attachments/95446171/btn-h-contents.jpg – Shows the contents of the help system.
  • images/download/thumbnails/95446171/btn-h-tutorial.jpg – Runs postprocessors generator tutorial.
  • images/download/attachments/95446171/btn-h-email.jpg – Prepare a message to the technical support service of SprutCAM Tech Ltd.
The main window
