Surface probing parameters
Surface probing consist of the following steps:
The tool moves the distance specified in the < Feed distance > and approaches the starting point of the measurement cycle. Moving at "Approach feed";
T he tool moves the distance specified in the < Clearance > and approaches touch point of the surface. Moving at "Work feed";
T he tool returns to starting point for a distance specified in the < Clearance >. Moving at "Retract feed";
T he tool returns for a distance specified in the <Feed distance >. Moving at "Return feed" .
Parameters:
Type |
Description |
CmdPrm.Int[-1] |
Integer |
Probing cycle type: Surface probing value = 2 |
CmdPrm.Int[-2] |
Integer |
SubCode of cycle specified in "SubCode for postprocessor" property on the <Job Assignment> tab |
CmdPrm.Flt[-50] |
Double |
CmdPrm.Flt[-100] |
Double |
Touch point value along X-axis |
CmdPrm. Flt [-101] |
Double |
T ouch point value along Y-axis |
CmdPrm. Flt [-102] |
Double |
T ouch point value along Z-axis |
CmdPrm.Flt[-103] |
Double |
Target vector value along X-axis |
CmdPrm. Flt [-104] |
Double |
Target vector value along Y-axis |
CmdPrm. Flt [-105] |
Double |
Target
vector
value along Z-axis
CmdPrm. Flt [-56] |
Double |
Clearance, approach distance to touch point |
