Drilling cycle G87 <W5DBore7>
Boring cycle <W5DBore7(487)> (G87) performs tool approach to the hole center, hole boring with stop at minimum level and manual retract to the <Return> level.
Boring canned cycle G87 consists of:
Rapid travel to the hole center at the <Z return> level.
Rapid travel to the <Z safe> level.
Work feedrate travel to the <Z min> level.
<Spindle stop>. If oriented spindle stop is enabled (CLD [14] parameter), it is positioning the spindle in a given angular position and then tool shifts to specified small value of the X, Y and Z coordinates.
Manual retract to the <Z return> level.
Restore spindle rotation direction and speed.
Parameters:
Description |
CLD[1] |
CLD.SubCmd |
CLD[2] |
CLD.SubType |
Canned cycle type identifier: W5DBore7(487) (G87). |
CLD[3] |
CLD.CLParams(1) |
Nx, X coordinate of the tool normal vector |
CLD[4] |
CLD.CLParams(2) |
Ny, Y coordinate of the tool normal vector |
CLD[5] |
CLD.CLParams(3) |
Nz, Z coordinate of the tool normal vector |
CLD[6] |
CLD.CLParams(4) |
Sf, Normal distance from current tool position to the safe plane level |
CLD[7] |
CLD.CLParams(5) |
Tp, Normal distance from current tool position to the hole top level |
CLD[8] |
CLD.CLParams(6) |
Bt, Normal distance from current tool position to the hole bottom level |
CLD[9] |
CLD.CLParams(7) |
Work feed measurements: 0 – mm/rev, 1 – mm/min |
CLD[10] |
CLD.CLParams(8) |
Work feed value |
CLD[11] |
CLD.CLParams(9) |
Approach feed measurements: 0 – mm/rev, 1 – mm/min |
CLD[12] |
CLD.CLParams(10) |
Approach feed value |
CLD[13] |
CLD.CLParams(11) |
Return feed measurements: 0 – mm/rev, 1 – mm/min |
CLD[14] |
CLD.CLParams(12) |
Return feed value |
CLD[17] |
CLD.CLParams(15) |
The state of the oriented spindle stop at the bottom of the hole: 0 - off, 1 - enabled. |
CLD[18] |
CLD.CLParams(16) |
The angular position of the spindle when stopping at the bottom of the hole (degrees) |
CLD[19] |
CLD.CLParams(17) |
The value of tool shift for the X coordinate after oriented spindle stop at the bottom of the hole. |
CLD[20] |
CLD.CLParams(18) |
The value of tool shift for the Y coordinate after oriented spindle stop at the bottom of the hole. |
CLD[21] |
CLD.CLParams(19) |
The value of tool shift for the Z coordinate after oriented spindle stop at the bottom of the hole. |
CLD[50] |
CLD.CLParams(48) |
What spindle is used to machining: 1 - driven tool, 2 - workpiece spindle (lathe). |
