Drilling cycle G82 <W5DFace>
Drilling cycle type <W5DFace(482)> (G82) drills holes with rapid approach to the safe level, dwell at hole bottom level and rapid retract the safe plane level.
Drilling cycle G81 consist of the following steps:
Rapid tool motion to the hole center at the <Z return> level.
Rapid descend to the <Z safe> level.
Work feedrate motion to the <Z min> level.
<Dwell> at the <Z min> level.
Rapid tool return to the <Z return> level.
Parameters:
Description |
CLD[1] |
CLD.SubCmd |
CLD[2] |
CLD.SubType |
Canned cycle type identifier: W5DDrill(481). |
CLD[3] |
CLD.CLParams(1) |
Nx, X coordinate of the tool normal vector |
CLD[4] |
CLD.CLParams(2) |
Ny, Y coordinate of the tool normal vector |
CLD[5] |
CLD.CLParams(3) |
Nz, Z coordinate of the tool normal vector |
CLD[6] |
CLD.CLParams(4) |
Sf, Normal distance from current tool position to the safe plane level |
CLD[7] |
CLD.CLParams(5) |
Tp, Normal distance from current tool position to the hole top level |
CLD[8] |
CLD.CLParams(6) |
Bt, Normal distance from current tool position to the hole bottom level |
CLD[9] |
CLD.CLParams(7) |
Work feed measurements: 0 – mm/rev, 1 – mm/min |
CLD[10] |
CLD.CLParams(8) |
Work feed value |
CLD[11] |
CLD.CLParams(9) |
Approach feed measurements: 0 – mm/rev, 1 – mm/min |
CLD[12] |
CLD.CLParams(10) |
Approach feed value |
CLD[13] |
CLD.CLParams(11) |
Return feed measurements: 0 – mm/rev, 1 – mm/min |
CLD[14] |
CLD.CLParams(12) |
Return feed value |
CLD[15] |
CLD.CLParams(13) |
Delay at the bottom level in seconds |
CLD[50] |
CLD.CLParams(48) |
What spindle is used to machining: 1 - driven tool, 2 - workpiece spindle (lathe). |
