Application toolbar
Application toolbar placed on the top left panel of the main window.
images/download/attachments/79697036/image2021-6-3_13-3-5.png
There are drop-down menus associated with some buttons.
images/download/thumbnails/79697036/image2021-6-3_13-3-43.png
The main drop-down menu appears when you click on the system logo and contains the following items.
images/download/thumbnails/79697036/image2019-1-9_18-14-36.png The New button closes the current project and initiates the system state anew.
images/download/thumbnails/79697036/image2020-3-25_17-41-40.png The Load button loads an existing project from a file (open dialog will appear). When you hover the mouse over the button, a list of recently opened projects appears. A click on one of them leads to the opening of this project.
images/download/thumbnails/79697036/image2019-1-9_18-23-48.png The Save button saves all changes in the current project. If the project has not been saved before, a new name will be requested. The drop-down menu for this button contains the following items.
  • Save as... Saves the project under a new name. The save dialog will appear.
  • Export 3D Model... Opens a window to export 3D model to one of a external format.
  • Export simulation result... Opens a window to export simulation result to STL format.
  • Export drill points... Opens a window to export drill points of a current operation (if it has Holes page in properties) to DXF-file. The file with these points can be imported later to the model page of another project.
images/download/thumbnails/79697036/image2020-3-25_17-43-3.png Smart snap. Enable / disable snapping to objects in the graphics window.
images/download/thumbnails/79697036/11-28-Geometry_measuring.png Geometry measuring. Activates the mode of measuring objects in the graphics window.
images/download/thumbnails/79697036/image2020-3-25_17-46-54.png . Turns on the mode of measuring distances between two arbitrary points on the screen.
System's main window
