Export simulation result as model
Click the
in the simulation mode or <Export simulation result> in the main menu to save the simulation result that is on the screen to the file. Input the exported file name in the STL format. The file you will get can be used as a workpiece in the another SprutCAM project or in the any software that can import STL file format.
