Collisions
If you are using inaccurate 3D models, SprutCAM can detect false-positive collisions between nodes. You can add these nodes to the ignore-list to prevent SprutCAM from detecting false-positive collisions.
Click button to open the parameters panel. Then go to the Collisions tab.
Select first and second nodes and click Add collisions button. Use with children toggle to add node's children to the ignore-list. Use button to delete a previously added collision from the ignore list.
SprutCAM always ignores collisions between sibling nodes. So it is not necessary to add them to the ignore list.
