Plunge height
The height of the layer is set in the <Plunge height> panel; in particular, it defines a value of level Z on which the given type of plunge will join.
<From previous level> – Plunge will join at once at driving downwards to the following level
<From level (Z)> – the scheme of plunge will be powered up always at driving downwards from the given level.
<Height (H)> – the scheme of plunge will join on distance H from a treated plane.
Defining the machining strategy
