Assigning rough pass in the XY plane
Roughing passes for closed and open curves in 2D machining operations can be set up in the <Strategy> window.
When activating this option, the stock from the model will not be removed in one go; instead, it will be done according to the assigned parameters. The value of the stock can be defined as the absolute value or as a percentage of the tool diameter.
