Designation of the simulation mode
SprutCAM X has the embedded high quality multi-axis mill/turn machining simulation module. The module allows exact simulation and error checking of turning, threading, drilling and multi-axis milling.
Click the <Simulation> bookmark to switch on the simulation mode. The mode allows:
- to control by eyes the cutting process;
- to see the machining quality and to discover the possible defects;
- to compare the machined part with the source model;
- to discover and to mark the problem tool path fragments using the different criterions;
- to edit the calculated tool path to bring to the requirements of the user;
- to optimize the feed rates.
While simulating mill operations true solids are used to represent a tool and a workpiece. Thus, the quality of a resulting workpiece does not rely neither on the tool or the view orientation. The used method ideally suit for multi-axis simulation.
While simulating turn operations solids of revolution are used to represent a tool and a workpiece irrespective to the form of the source models. It is so to gain an effect of a revolving workpiece on a machine. If a mill operation follows a turn one, the true solid model is used for its simulation again.
