The list of the basic CL-data commands
The CLDATA command that is generated by SprutCAM is listed in the table. The full list of the CLDATA commands see in the part 3 of this manual <Postprocessors generator>.
Command |
Description |
AXESBRAKE |
Machine axes brakes control |
CIRCLE |
Motion by circle arc |
COMMENT |
Commentaries |
COOLNT |
The coolant Switch on/off |
CUTCOM |
The tool radius and tool length compensation |
DELAY |
Delay of time |
EDMMOVE |
EDM movement |
EXTCYCLE |
Extended cycle (drilling cycle, lathe cycle, milling cycle) |
FEDRAT |
Feedrate |
FROM |
Original point of the toolpath |
GOHOME |
Return to the home position |
GOTO |
The linear motion |
INSERT |
Insertion of a string to the NC code |
INTERPOLATION |
Different kind of Interpolation mode switch on/off |
LOADTL |
The tool loading |
MULTIARC |
Multiaxis circle movement |
MULTIGOTO |
Multi coordinate movement |
OPSTOP |
Optional stop of the NC code execution |
ORIGIN |
Coordinate system definition |
PhysicGOTO |
Physical machine axes movement |
PLANE |
The work plane (XY/YZ/ZX) |
PPFUN |
Postprocessor function |
RAPID |
Rapid feedrate |
SELWORKPIECE |
Active workpiece holder selection |
SINGLETHREAD |
Singlethread command |
SPINDL |
The spindle switch on/off |
STOP |
Stop of the NC code execution |
TAKEOVER |
Workpiece takeover into other spindle |
WAIT |
Waiting for synchronization point |
