Named block
To create a named block, you need to select the necessary elements in the block. To do this, by pressing the mouse button and holding it down, select the elements with a rectangular frame, or sequentially select the elements with the [Shift] key pressed. The exclusion of elements from the block is also performed by specifying these elements with the [Shift] key pressed.
images/download/attachments/95434003/blocks8.jpg
Click the images/download/attachments/95434003/blocks10.jpg button in inspector. If necessary, you can enter its name or set the rotation angle of the block.
images/download/attachments/95434003/blocks9.jpg
In the future, you can insert this block into the drawing by hovering over the corresponding button and selecting the desired block from the drop-down menu.
images/download/attachments/95434003/blocks11.jpg
Subsequently, you can edit the original block by clicking the "scissors" in the menu. All copies of the edited block will also change.
images/download/attachments/95434003/blocks12.jpg
