Split object
images/download/attachments/95433984/split.jpg
The function converts the specified compound element (rectangle, contour, named block) into its parts. If a block is pointed, it will be split into the elements from which it was built.
If you select an elementary object (line, arc, circle), this element will be split into several at the intersection points with other elements.
images/download/attachments/95433984/example76.jpg
