Fast calculation method
The < Use fast calculation method > option is available for most 3d milling operations . The option is found in the Miscellaneous operation parameters tab.
images/download/attachments/95436389/image2022-4-6_17-9-43.png
If < Use fast calculation method > is used, toolpath calculation time reduces dramatically. A speedup on complex parts may reach up to 10–20 times.
By now, fast toolpath calculation methods use triangulated surfaces as input data. This fact involves some limitations that should be taken into consideration while generating toolpath. First of all, the quality of the generated toolpath may be worse than when using traditional exact methods. The maximum deviation of the toolpath depends heavily on the value specified in the < Deviation > panel of the operation parameters dialog. This value determines the tolerance of model triangulation. Secondly, triangulated surfaces require a lot of operation memory.
Described limitations are today a common place for all CAM systems, and only SprutCAM X gives you the alternative between speed of approximate calculation methods and the quality of exact calculation methods.
Mill machining
