Check holder
The Check holder feature detects segments of the toolpath where the tool holder collides with the part and modifies those segments according with the specified strategy.
Strategies
Trim toolpath
The colliding segments are excluded from the toolpath.
Frontal tilting
The tool tilts in the frontal direction to avoid collisions.
Side tilting
The tool tilts sideways to avoid collisions.
Offset along tool
The tool retracts along its axis to avoid collisions.
Parameters
Clearance
The minimum allowed distance between the holder and the part.
Check tool
The option enables checking of the tool collisions alongside with the holder collisions.
Additional tilt angle
The additional clearance angle used for tilting to guarantee a safe collision-free toolpath. The greater the value is, the farther the tool tilts away from the collision.
Max. tilt angle
The maximum allowed tilting angle.
Smooth factor
The parameter controls smoothness of the tilting. The greater the value, the smoother the tilting is. 0 means no smoothing.
Blend distance
The blend distance is the distance between two points of the toolpath before and after the current tool position used for the calculation of the current tool movement direction which in turn is used to calculate the current tool tilting direction. Use greater values when machining irregular shapes with a lot of small bumps to eliminate unnecessary tool axis oscillations. Use values greater than the holder radius when machining inner corners.
