Helical operation
Parameters
Step
The vertical distance between any two adjacent complete helix turns.
Strategy
Use the Start From parameter to choose between the top-down and bottom-up machining. Use the milling type parameter to choose between climb and conventional milling.
Job zone
The whole part is being machined. The Top and the Bottom levels of machining can be specified.
