SpaceClaim™ toolbar & import addin
images/download/attachments/95433455/SpaceClaimFromAddinManager.png
The toolbar allows you to export geometric data from SpaceClaim™ to SprutCAM X™.
images/download/attachments/95433455/image2022-3-30_15-42-57.png
The addin allows you to import SpaceClaim™ project files.
Supported file extensions: SLDASM, ASM, SLDPRT, PRT, SLDDRW, DRW, X_B, X_T, STP, STEP.
The required application (SpaceClaim™) must be installed on your computer for the correct work of this option.
Associativity
Default exchange between SpaceClaim™ and SprutCAM X™ is performed by Parasolid files (associativity is maintained). But this module is not included in the standard package of components for SpaceClaim™, therefore the possibility of manual shifting for exchange file was realized. In this case, the associativity would be lost, but export function stays available.
Expansion change instructions:
  1. Go to the folder where the addin files (depends on the version, the path can vary, e.g.: "C:\ProgramData\SprutCAM Tech\SprutCAM X\Version 16\Addins\SpaceClaim");
  2. Copy SpaceClaimTranslator.xml file and rename the copy as SpaceClaimTranslator_UserConfig.xml;
  3. Move this file to the directory above (for example: "C:\ProgramData\SprutCAM Tech\SprutCAM X\Version 16\Addins\SpaceClaimTranslator_UserConfig.xml");
  4. Open SpaceClaimTranslator_UserConfig.xml file and change the extension at line <OutputExtension>:
  1. X_T - for Parasolid (only it maintains associativity);
  2. STP - for STEP;
  3. IGS - for IGES.
Deleting or renaming of SpaceClaimTranslator_UserConfig.xml file would lead to the default settings.
Addin's list
