Importing objects from 5DC files
<5DC> format allows loading a splines as a set of points(xyzijk). The main features:
  • maintained only text format UTF-8 encoded
  • allows to contain multiple splines: as a separator, use the symbol ";" (semicolon) on a new line. After the symbol, you can specify the name of the curve.
  • minimum number of spline points(lines) should not be less than 2
  • the first line of the file instead of dots may contain settings
If the first line of the file does not contain any settings, then for each line including the first one:
  • coordinate numbers are separated by a space
  • point is provided as 6 numbers: "X Y Z NX NY NZ", when (X,Y,Z) - coordinates of a point , (NX,NY,NZ) - normal vector
If the first line of the file contains the settings, then for each line except the first one:
  • the number of coordinates is separated by the separator specified in the settings line
  • the point is represented as multiple numbers, according to the format specified in the settings line
If the settings line is set, it must contain three mandatory parameters and may contain six optional parameters. The parameters should be separated by a space.
Mandatory parameters:
  • Point number format:
Format
Description
Number of points in a line
tffNormalVector
Coordinates of the point and normal
tffQuaternion
Coordinates of the point and quaternion X Y Z W
7
3
tffEulerXYZ
Coordinates of the point and Euler angles Rx Ry Rz with rotations around the movable axes
tffEulerXZY
Coordinates of the point and Euler angles Rx Rz Ry with rotations around the movable axes
tffEulerYXZ
Coordinates of the point and Euler angles Ry Rx Rz with rotations around the movable axes
tffEulerYZX
Coordinates of the point and Euler angles Ry Rz Rx with rotations around the movable axes
tffEulerZXY
Coordinates of the point and Euler angles Rz Rx Ry with rotations around the movable axes
tffEulerZYX
Coordinates of the point and Euler angles Rz Ry Rx with rotations around the movable axes
tffEulerXYX
Coordinates of the point and Euler angles Rx Ry Rx with rotations around the movable axes
tffEulerXZX
Coordinates of the point and Euler angles Rx Rz Rx with rotations around the movable axes
tffEulerYXY
Coordinates of the point and Euler angles Ry Rx Ry with rotations around the movable axes
tffEulerYZY
Coordinates of the point and Euler angles Ry Rz Ry with rotations around the movable axes
tffEulerZXZ
Coordinates of the point and Euler angles Rz Rx Rz with rotations around the movable axes
tffEulerZYZ
Coordinates of the point and Euler angles Rz Ry Rz with rotations around the movable axes
tffFixedABC
Coordinates of the point and Euler angles Rx Ry Rz without rotations around the movable axes
tffFixedXZY
Coordinates of the point and Euler angles Rx Rz Ry without rotations around the movable axes
tffFixedYXZ
Coordinates of the point and Euler angles Ry Rx Rz without rotations around the movable axes
tffFixedYZX
Coordinates of the point and Euler angles Ry Rz Rx without rotations around the movable axes
tffFixedZXY
Coordinates of the point and Euler angles Rz Rx Ry without rotations around the movable axes
tffFixedZYX
Coordinates of the point and Euler angles Rz Ry Rx without rotations around the movable axes
tffFixedXYX
Coordinates of the point and Euler angles Rx Ry Rx without rotations around the movable axes
tffFixedXZX
Coordinates of the point and Euler angles Rx Rz Rx without rotations around the movable axes
tffFixedYXY
Coordinates of the point and Euler angles Ry Rx Ry without rotations around the movable axes
tffFixedYZY
Coordinates of the point and Euler angles Ry Rz Ry without rotations around the movable axes
tffFixedZXZ
Coordinates of the point and Euler angles Rz Rx Rz without rotations around the movable axes
tffFixedZYZ
Coordinates of the point and Euler angles Rz Ry Rz without rotations around the movable axes
tffTwoAngAB
Coordinates of the point and two angels AB
5
28
tffTwoAngAC
Coordinates of the point and two angels AC
5
29
tffTwoAngBA
Coordinates of the point and two angels BA
5
30
tffTwoAngBC
Coordinates of the point and two angels BC
5
31
tffAxisAngleRad
Coordinates of the point and axis-angle in radians
tffAxisAngleDeg
Coordinates of the point and axis-angle in degrees
  • The angles are specified in degrees: True (degrees)/False (radians). Relevant for the formats in paragraphs 3-30.
  • Separator-Always one character.
Optional parameters (additional transformation):
  • Transformation along the X-axis. X=N, where N is offset value
  • Transformation along the Y-axis. Y=N, where N is offset value
  • Transformation along the Z-axis. Z=N, where N is offset value
  • Rotation to a A-angle. A=N, where N - rotation angle value
  • Rotation to a B-angle. B=N, where N - rotation angle value
  • Rotation to a C-angle. C=N, where N - rotation angle value
Example of a file that does not contain settings line:
format5DC.5dc
; first
0.000000 0.000000 0.000000 -1.000000 0.000000 0.000000
0.000000 50.000000 0.000000 0.000000 0.000000 1.000000
50.000000 50.000000 0.000000 0.000000 1.000000 0.000000
50.000000 50.000000 50.000000 1.000000 0.000000 0.000000
; second
25.000000 0.000000 0.000000 0.000000 0.000000 1.000000
50.000000 50.000000 -50.000000 0.000000 1.000000 0.000000
The result of adding a curves in Job assignment by the buttonimages/download/thumbnails/95433306/image2019-1-11_17-27-44.png in 5D Contouring operation is shown on the following image :
images/download/attachments/95433306/image2019-10-16_15-45-27.png
Example file, with settings line:
format5DC_2.5dc
tffEulerXYZ true , A=0.00 B=0.00 C=0.00
0.000,0.000,0.000,0.000,-90.000,0.000
0.000,50.000,0.000,0.000,0.000,90.000
50.000,50.000,0.000,-90.000,0,0.000
50.000,50.000,50.000,-90.000,0,0.000
The result of adding such a curve in Job assignment by the buttonimages/download/thumbnails/95433306/image2019-1-11_17-27-44.png in 5D Contouring operation is shown on the following image:
images/download/attachments/95433306/format5DC_2_eng.png
